Thanks - but I'm not counting my chickens before I've seen it cut!
I had a quick go at getting it moving this morning, but unfortunately one of my Z-axis Gecko's is stuck in fault-mode I had a quick check of the wiring but didn't find anything, so I'll try swapping it with my A or B axis one for now - I really hope it isn't toasted, it's a long round trip to send it for repair!
I have a nasty feeling I will be taking it apart again soon - I think the Z-axis columns need to go further back as the head is near the front edge of the table when the table is only 100mm or so from its forward limit. I do need to be able to go off the front of the table to reach the ATC stations though, hmm...
Squaring it all up is also going to be interesting - I should be able to indicate off the table to get the X-axis properly horizontal, but I don't have any accurate reference to allow me to get both Y-axis screw-assemblies perfectly lined up. Any suggestions would be most welcome!
