New Machine Build Concrete VMC - Page 22
Page 22 of 22 FirstFirst ... 1219202122
Results 253 to 259 of 259
Thread: Concrete VMC
  1. #253
    Jun 2017
    Italy
    Default Re: Concrete VMC
    @stef110
    I also own your servo kits. I did auto tuning. I had difficulty in synchronizing the axes. as a check you can try cutting octagon and measuring diagonals.
  2. #254
    May 2016
    @daniba73 Did you had these synchronizing error before or after tuning?
    This weekend welded the bottom of the enclosure, machine becomes pretty big!
    I gone mount a mist coolant on the head now first so i can start machining my atc parts and when the atc are done, i gone order the rest of the sheet metal for the rest of the enclosure.
    I also temporarily mounted the control panel above the machine so i can easily control the machine now
    Stef
  3. #255
    Jun 2017
    Italy
    I didn't try without automatic calibration, I thought it was a necessary practice.
    P.S I'm designing a VMC very similar to yours.
    I was thinking of using cement (with special characteristics) instead of epoxy granite.
    I'm Italian, the post I opened can be seen here: https://www.cncitalia.net/forum/view...78526&start=15
  4. #256
    Jun 2017
    Italy
    question:
    the welded parts, have you not subjected them to thermal distension?
    it's a very important phase!
    internal tensions are created by welding.
    with changes in the outside temperature, these voltages change.
    consequently they change shape.
    changing shape, it compromises stability and precision.
    another question:
    Do the protections you used go well with an emulsion jet?
    under the metal blades, is the sheet present to make the cover waterproof?
  5. #257
    May 2016
    The x axis sadle have been heat threaded after welding so that one should be perfect.
    The head however i didn't heat threaded because the main body is fillet with epoxy so i don't really see that al moving. Its a gamble on my side lets see how it gone turn out.
    Stef
  6. #258
    Jun 2017
    Italy
    was there a particular reason why you used epoxy instead of anti-retraction cement?
  7. #259
    Member mchlfranko's Avatar
    Jun 2018
    Burlington
    Quote Originally Posted by daniba73 View Post
    Go back to page 5 (post #53) and start reading from there. Lots of debate on the subject prior to Stef making a decision.
    Great job Stef! This looks amazing!
Concrete VMC
Concrete VMC
Concrete VMC
