New Machine Build Concrete VMC - Page 20
Page 20 of 20 FirstFirst ... 1017181920
Results 229 to 234 of 234
Thread: Concrete VMC
  1. #229
    Oct 2019
    Hi Stef,
    Great work! I have really enjoyed following your posts. Would you be willing to share your CAD files?
    Best,
    Nick
  2. #230
    May 2016
    Default Re: Concrete VMC
    This weekend i put the oil system in to work, unfortunately the pump is a wrong one. It doesn't release the pressure fast enough after the pump stops so the oil blocks doesn't function properly. Need to find myself a solenoid valve that can handle oil so when the pomp stops the valve opens and release the pressure from the circuit so the springs in the oil blocks can shoot the oil in the linear cartridges and ball nuts.
    Also milled the sub plate that's under the table flat so i have a nice flat surface where on i can mound the steel mounting table. Unfortunately that also didn't go to plan. After milling i wanted to check it but there was a error in the Y direction. Later i figured out with some help from Vakeiros that is had to do with spindle grow due to heat. So today i remilled the sub plate but before that i let the spindle run for an hour so the temperature was stable and after that i measured it again and on every spot on the table just spot on.
    Today i also made a small movie trying to explain somethings about the machine. Its the first time i made such a movie so its not perfect and my English is also not that great but anyway here it is.
    Stef
  3. #231
    Dec 2016
    Norway
    Great work!
    How much error did you get the first time you milled the plate?
    It looks like you video is removed from youtube btw.
  4. #232
    Member klaas123's Avatar
    Sep 2014
    The Netherlands
    Here is the new video:
  5. #233
    May 2016
    Quote Originally Posted by Buoyen View Post
    Great work!
    There was a difference off 0.04mm from beginning of the table to the end. Yes the video get blocked by youtube so i made a new one
    Stef
  6. #234
    Aug 2016
    Been watching your progress since post 135. Awesome work! Always love seeing projects come to completion!
Concrete VMC
Concrete VMC
Concrete VMC
