New Machine Build Concrete VMC - Page 12
Page 12 of 12 FirstFirst ... 29101112
Results 133 to 136 of 136
Thread: Concrete VMC
  1. #133
    May 2016
    Default Re: Concrete VMC
    Some fine adjustments was needed to align the bold holes of the column. XD
  2. #134
    Aug 2009
    Quote Originally Posted by stef110 View Post
    Just a little "tappy tap tap tap"
  3. #135
    May 2016
    Not that much off an update, this weekend managed to get x and y axis to move. First i made 2 anti backlash nut holders there are 2 nuts in it pressed outwards with springs. To eliminate backlash because i only use c7 rolled ballscrews.
    Hooked the controller up to the servo drives to get it to move.
    Managed to buy a secondhand 17inch build in touchscreen for the control panel.
    Now i really need to finish the head design and let it laser cut.
  4. #136
    Dec 2015
    Excellent work. So glad you have made it this far and brought us along with you on the journey.
    Looking forward to further progress.
Concrete VMC
Concrete VMC
