Build Thread Gantry mill with moving gantry for Z-axis - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Gantry mill with moving gantry for Z-axis
  1. #21
    Jan 2008
    Default Re: Gantry mill with moving gantry for Z-axis
    Downside of a simple counterweight is that you have increased inertia to deal with.
    It is simple and cheap though.
  2. #22
    Jan 2008
    https://www.vulcanmachineco.com/
    This company is developing a mill with a rising gantry and it looks like single central screw.
    They have some YouTube videos that show it
  3. #23
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Pippin - Good find. I think this config makes so much sense! Now to do it in Tetrium....cheers Peter
  4. #24
    Jul 2018
    dum dum
    Vulcan mechanics renders - Peter
    Attached Thumbnails Attached Thumbnails Gantry mill with moving gantry for Z-axis-vulcan-2-jpg   Gantry mill with moving gantry for Z-axis-vulcan-1-jpg
  5. #25
    May 2011
    Yeah, that's the way to do it. Looks like that machine is well thought out. I wonder how much they will sell for?
    It only has travels of 13" x 13" on X and Y. 12" x 24" would be so much better IMO. But it's really nice that it can fit through a standard door opening. I wonder at what width it would need a second screw to prevent racking with the given bearing spacing.
    Since the table can't actually pass beneath the columns, I still consider this to be a single column design. But really nice find of a rising gantry. I could see these becoming quite popular. Thanks for sharing.
  6. #26
    Jul 2018
    dum dum
    hi Nic - The first batch is at $7000USD can see them making much -$$$ from that., Then they are going to set a new price. I looked at some of their videos. Initially they had the table go thru the columns as you would expect but they changed that along the way. The working envelope is small for the config. A mill such as attached can get 330x330x355mm easily and is cheaper. They have some sorting out to do I expect. Peter
    wracking should be prevented by the bearing system not the drive system.
    Attached Thumbnails Attached Thumbnails Gantry mill with moving gantry for Z-axis-combo-mill-jpg
  7. #27
    May 2005
    canada
    Quote Originally Posted by NIC 77 View Post
    Yes, that seems like an unnecessary limitation. The machine is well thought out otherwise so I must be missing something.
    edit/ It also looks like the table could be wider (y direction) with no real downside.
    Anyone who says "It only goes together one way" has no imagination.
