Thanks Kevin.
I've grounded the spindle to 45.00 for the main bearings and 40.00mm for the upper bearings however the bearings wont fit easily. It's a hard press fit. So I tried to read about tolerences and clearences but the given info is not something like I can understand. Very technical you see. Can someone help me on this?
My 7009C bearings are 45mm ID
and my 7008's are 40mm id
so how much OD do I need on the splindle for a light press fit?
Thanks in advance.
