Great job, that thing's a manly-man! I missed this thread somehow and am glad it was bumped up.
I noticed you're using Dolphin & Mach3...me too! Someone asked you earlier in the thread about Mach & CSS. You can use CSS by choosing that option in the Select Tool screen in Dolphin but you can't use the feed per rev option with it; you have to use feed per minute. It won't be true CSS but the spindle speed will speed up & down in proportion to the diameter changes Mach screws up if you try CSS with the feed/rev option.
