- Build Thread- Project Frankenmill: Sieg X3+Tormach 770 Spindle Head
I purchased this from McMaster.
http://www.mcmaster.com/#8082k85/=pvrodj
16awg 4 conductor, shield and drain. 3.86 per foot.
Has been working well on my router with lots of movement in the cable.
Sent from my iPad using Tapatalk HD
That stuff looks good, thanks for the pointer. I might consider their continuous flex 18AWG 4 conductor if I get around to rewiring my X/Y steppers. When I first built the machine I was cheap and used 4 conductor 18AWG stranded in-wall speaker wire from Monoprice. It's held up OK for four years, but it's really not the right cable for the job.
I love living vicariously through other peoples projects. This has been an awesome build
Nice job. I'd love to have a 10k spindle on my machine, but that head is out of my price range.
Thanks for the kind words, guys. I'm not sure my workmanship is worthy of such praise, but I'm trying new things and learning and that's what matters to me.
ChrisAttebery: Definitely... I don't recommend this as a cost-effective way to go. It's a silly project in a lot of ways, but it's fun at least.
Dumb Question... what did you do with your X3 head?
I ask because I am going to rebuild my X2. Its not really a "rebuild", more like replacing the X2, with another very similar build to my tormach build. If you want to sell it, I hope you keep me in mind. I live in Jersey, so I am sure the shipping would be brutal.
Re: Project Frankenmill: Sieg X3+Tormach 770 Spindle Head
Wow. It's been almost a decade since my last update on this thread.
Not long after I grafted the Tormach 770 head onto my X3, I ended up getting seriously involved in my local maker space. I helped the space purchase a Tormach 1100 in 2016, and I taught CAM and CNC machining to members for a few years. Having access to the 1100 meant I had less need for my own machine at home, but I still used it occasionally, mostly when I didn't feel like making the drive to use the 1100. But the flaws, particularly in the Z axis dovetail ways and poor gib fit, continued to plague the machine.
I've been dusting off old projects lately, and I got the urge to continue where I left off all those years ago and see if I could pull off a linear rail conversion on the column to help this issue. On the plus side, I've improved my machining and design skills over the last decade. On the minus side - is an old converted X3 even worth the time or money anymore in 2023? Probably not. But the machine has been a great platform for learning, so pushing my design/machining/metrology skills with a machine that already mostly works, that I already have in my shop seemed sensible. The alternative path I was considering was a new conversion of a different machine, or even scratch-building a machine. Both more ambitious projects for sure.
Another plus is that I now have access to a lot of machines that I did not back in 2013 - the aforementioned Tormach 1100, a ProtoTrak BridgePort mill, and an ProtoMax waterjet... This would be a good project to put those all to use.
So a bit of a review... The X3 has a poorly designed Z axis drive setup for CNC use, with the leadscrew/ballscrew located in the back of the column and plates that wrap around the column to drive the slide in the ways on the front of the column. This, combined with the generally poor fit of the dovetails and gib, create a situation where the Z gib adjusters must be left fairly loose to avoid binding. The ball screw tends to lead the head due to the cantilevered nature of the setup, and with the loose gib, it tends to make the head "nod," or rock in the slideways when Z moves. It's a major contributor to poor surface finish.
Here are a couple photos from my initial conversion in 2009.
And here we are with the head removed again in 2023.
I briefly considered making a whole new column from scratch, but abandoned that idea in favor of modifying the existing one. And instead of milling off the existing dovetails, as is common, I got to thinking about spinning the column around 180 degrees and mounting rails to the column sides somehow. This is the basic starting point with the flipped column.
Initial considerations as of March 2023...
- how/where to mount linear rails
- re-use old Thompson 16mm dia ballscrew or upgrade?
- new location for Z axis motor?
- possible to improve torsional rigidity of the "open box" design of the original column by partially closing it in?
- possible to improve overall rigidity by improving/expanding mounting surfaces between column and base? adding stiffening members to the column itself?
The project has been moving forward since then - I will make a series of posts to catch up with where I am now.
Before attaching the side bars, I had done some measuring of the column on a granite surface plate and was able to confirm that the original precision ground surfaces on the front and back of the column were in fact parallel and true within reason. One corner had a slight dip, but clearly these surfaces had been machined and ground in the original setup to cut the dovetails. Years ago I had confirmed that the column was relatively square to the Z travel within reason, so I was able to use these ground surfaces as references for setup and machining.
For extra security, I decided to epoxy the side bars to the column so they would not move. I figured the epoxy would also help fill in the troughs of the roughly fly cut cast iron surface and provide a more solid connection. I just used JB Weld here, nothing exotic.
Once cured, I set up a 2-4-6 block with an indicator to slide along the front (formerly rear) reference surface of the column, so I could measure the position of the side bars relative to one another and find the high and low spots. Since I did the bolt hole work in a low-precision way with traditional layout, transfer punches, and a drill press, I knew it would not be that precise. But I also knew the final surfaces would be machined for flatness. These measurements were used so I knew how much I needed to machine off to make both rail mounting surfaces parallel to the reference and with each other.
I set up on the Bridgeport and machined clearances on the back side so I would be able to flip the column and support it on 1-2-3 blocks on the old precision dovetail surfaces, without interference from the newly added side bars sitting slightly askew.
The extra holes on the back side of the side bars are for potential future stiffening plates or fixturing bolts for E/G.
Milling the clearance on the back side of the side bars. Using a 1 inch indexable end mill with two APKT aluminum inserts, and the old ProtoTrak in basic power feed mode for the long cuts.
One "gotcha" is that the X travel on our Bridgeport is nominally only 24" (610mm), limited in part by the motor for the ProtoTrak setup. I chose 640mm linear rails, and the aluminum side bars are even longer still. So it's not possible to mill the whole back side for clearance in a single setup.
Thankfully after doing this operation, I discovered that it's possible to squeeze about 26" of travel out of the X axis with care. And the 1" diameter end mill gets some additional clearance at the two ends. That was a relief, as it would make the critical machining for the linear rails much more simple.
I did an initial mounting of the rails to check for parallel when using the two reference edges that I milled. With minor tweaking of the secondary rail, things look good at first glance. This is only a 0.0005" indicator, and there is a tiny amount of movement probably on the order of 0.00015 (~3.8 um).
I didn't spend a lot of time with this because I had to pull the rails back off to do more machining for the ball screw.
I considered re-using my original Thomson 16mm 0.200" pitch ball screw from the original CNC conversion kit that I used, but the ball nut wasn't sounding particularly good after the years of use. The screw also seemed to have developed a slight bend, perhaps as a result of the buckling load of the heavier Tormach head. The final straw was stumbling across the original Acme lead screw from the machine's manual days, and it was much larger - about 25mm.
A 20mm ball screw probably would have been a sufficient upgrade to prevent buckling, but given the small price difference to step up to a 25mm, I opted for that based more on gut feel than calculations. The screw radius has a 4th power effect on the inertia of the system, so it can have a large impact on required motor to achieve the desired acceleration. I already planned on an upgraded Z motor for this conversion, so hopefully I'd be able to account for that. I chose a 5mm pitch, which is close to the original 0.200" pitch of the previous screw.
I opted for an affordable rolled screw, figuring that this machine is really not worthy of expensive ground screws. I did buy from a vendor that matched ball nut to the screw, claiming 0.001" backlash as shipped, presumably by hand-sizing the balls loaded into the nut. I ordered the screw with the ends machined to match a pair of genuine Taiwanese SYK BF20/BK20 end supports.
My intent was to use the original support mounting positions, but I'd have to account for the different bolt hole spacing of the larger supports. I decided to try filling the original holes with JB weld epoxy and then drilling/tapping new holes. There would be some overlap of the new and old holes, which caused some minor headaches.
Due to the tight quarters inside the walls of the column, I couldn't come up with a workable combination of collet or chuck to hold a center drill to start the new holes in the proper bolt locations. I forged ahead and tried it without center drilling first and had a host of nightmares with the drill wandering. Surprisingly the wandering was not when making the initial hole, but as I drilled deeper into the cast iron. I think some of it was related to the epoxy-filled holes as mentioned above - it tended to wander to the softer material. I also think some was my inexperience with feeling out the required quill pressure and peck depths deep-drilling in cast iron. Suffice it to say the holes wandered more than I was happy with, but I did manage to get them tapped and I think they are still true enough to use. I had to abandon one hole and 'erase' by plunging a 0.5" end mill to remove the attempt. I will have to plug this with a turned piece of steel and loctite and try again.
Next up, I needed to create clearance for the end support and ball screw to project through the top of the column. I was reluctant to do this, since I knew removing that much material would reduce the rigidity of the column, but I was confident I'd be able to gain that back by adding a plate on the new face of the column afterwards.
After that, this is what I was left with.
And here it is with the ball screw, nut, end supports loosely test fit.
The original CNC conversion had a NEMA23 stepper located on the bottom of the column, driven by a belt. I'll be moving to a directly-driven NEMA34 at the top of the column.
I chose a 4.5Nm (637oz-in) NEMA34 closed-loop stepper with an electromagnetic brake from StepperOnline. I'm hopeful that my back-of-the-napkin motor calculations will work out, and I'll be able to hit my desired acceleration/velocity and meet the torque needs.
The brake will be a nice addition - in my original conversion I did not have a brake, so the head had a tendency to drop when the power was removed. I had a precisely calibrated stick that I would jam under the head to stop this, but it was a nuisance.
I tested the motor and driver out on the bench by writing a quick bit of Arduino code.
I took a chance and ordered a $17US coupler from Amazon, to couple from the 14mm shaft of the motor to the 17mm turned end of the ball screw. Unfortunately the runout was truly awful and I returned it. I ended up ordering a much more expensive one through Misumi to get something that ran true. Obviously the OD of the coupler doesn't strictly need to be concentric with the shaft bore, but the whole thing wobbled under testing, so I suspect this runout might be real. I have a feeling these might be made with a standard bore size and then tossed into a 3 jaw chuck and bored to different ID's, with little attention to concentricity.
Now, making the stepper mounting plate for the new Z stepper.
We recently got a fun new toy at our makerspace, a ProtoMax waterjet. Limited to cutting in a 12" x 12" area, up to 1" thick. A wee baby waterjet, for sure, but perfect for a project like this.
I figured I'd test out the machine to rough the blank for the stepper mount, and do finish machining such as final bores and counterbores on our Tormach 1100.
I bought a piece of 1" thick 2024 plate to make the plate that mounts the head to the linear rail blocks. The piece was large enough that I could also make this stepper mount from it. I would have opted for thinner stock - 0.500" would have been fine, but I didn't have anything convenient on hand. Besides, this would be a good test cut, since I intend to use the waterjet to rough the head mount plate soon.
This took 81 minutes to cut, but that's mostly just babysitting the machine to make sure it doesn't run out of garnet and there are no other problems.
Cut quality was much better than I expected.
Better taper on the cut than I expected from a simple 2 axis machine too.
And here it is sitting roughly in place, before final machining.
This plate is designed to allow two-axis adjustment via slots, to make the stepper and ball screw shafts concentric. Coaxial error can be corrected by shimming if necessary, if it's outside of what the coupler can handle.
And there we have it, we're caught up to present day. A couple months of work, after ten years of silence. Will anyone even notice this thread that came back from the dead? Stay tuned...
- You may not post replies
- You may not edit your posts
Forum Rules
