Hi:
I recently acquired a TMC-1000, that I used to use quite a bit at work. It has the old WIndows 95 DOS based software, and servo motors, w/controller. Recently, after getting it all set up, I tried firing it up, and although I can hear the motors energizing, like I used to, when I try and make the table traverse, in the X and Y, or the head in the Z axis, nothing moves. At first I thought it was a keyboard or mouse issue, but I can control the motor spindle through the interface. Any suggestions?
Also, is there a better way around the software issue, rather than using the clunky DOS software that came with it? i've tried to go back to Light Machines, but as you are aware of, I am sure, they want to treat me like I'm made of money
Thanks,
44 Echo
