Build Thread Emco 120p Rebuild - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Emco 120p Rebuild
  1. #21
    Member mactec54's Avatar
    Jan 2005
    slowtwitch
    Looks to be running very well, I have a PC120, that I have started on, I have put servo motors on it, but have not got to were you are at with it yet
    Mactec54
  2. #22
    Aug 2010
    Looking great!
  3. #23
    Registered trainman4602's Avatar
    Dec 2012
    Hi Pete
    I want to wish you all the luck in the world with the Emco. As you know we tried to get it working but as you mentioned to me many times it takes a lot of time and patience.
    I'll call you when the Hardinge is up and running. Also I will be starting to plan out the CNC plasma cutter/ router.
    Many thanks again my friend for the help. Dave the trainman
  4. #24
    Jan 2005
    slowtwitch
    What did you do to get the Turret all working, did you make a macro for it, or something else, also what board for the hardware/control side of it, everything on your 120P is the same as the PC120 I have, all the mechanical parts anyway
    Mactec54
  5. #25
    Jul 2006
    slowtwitch
    I'm using Andrew's board Emco Turret Controller for Mach , for the turret. I did have to write my first ever macro for the part pull out thing
    pete
  6. #26
    Jan 2005
    slowtwitch
    Thanks for the contact, your bar puller worked great, your whole build looks good in the video, I have a 140T as well, it is the same frame as the 220 just older
    Mactec54
  7. #27
    May 2010
    Default Re: Emco 120p Rebuild
    Hi Pete,
    I have enjoyed reading about your retrofit, I just picked up a 120P and will be retrofitting it as well. Have you been satisfied so far with your max spindle speed and other machine parameters?
    Cheers,
    Jacob
  8. #28
    Jul 2006
    Quote Originally Posted by Pantechnicon View Post
    Hi Pete,
    Cheers,
    Jacob
    Hi Jacob, I've been very happy with the lathe. Since the conversion, it has run flawlessly. I have set my max spindle speed to 4000 rpm, but I rarely go over 3000 rpm. The only drawback I had with the lathe was chips building up quickly in the tray. With the tool changer and puller, you kinda of see those chips pile up quickly
    pete
  9. #29
    May 2010
    Excellent, too many chips is a good problem to have! Do you have any posts about how you implemented the bar feeder? I see in the video you posted you are using something in the turret to pull the bar, I would love to know more....
    On my machine I have a complete T1 control and transformer so I am going to attempt to fire it up with RS-232 before I tear into it. We'll see how that goes.
    Cheers,
    Jacob
  10. #30
    Member manthanpatel45's Avatar
    Oct 2021
    DEar
    Have you tested in mach3? If yes, Then I need a tool changer scrip for the same
    Can you help
    Best Regards
    MAnthan
  11. #31
    Oct 2021
    Dear Train man have you run your emco..?
Emco 120p Rebuild
Emco 120p Rebuild
