Problems with Inlay pieces not getting cut correctly.
Results 1 to 2 of 2
Thread: Problems with Inlay pieces not getting cut correctly.
    Dec 2015
    Default Problems with Inlay pieces not getting cut correctly.
    OK, so I have done inlays before with fairly large pieces and have not had any problems but not I am working with some fairly skinny pieces and for some reason the cuts are not coming out correctly.
    I am doing an inlay that will be .3" deep and I using a 30 degree vbit. the pieces is about 4 inches long and about 0.125" wide.
    When I run the simulation on Vcarve it looks correct. below is a pic of what the simulation looks like.
    Problems with Inlay pieces not getting cut correctly.-20181003_151958-jpg
    However when I do the cut it looks like is is offset to the left. Not sure why that is but i have not seen this before when doing inlays.
    Problems with Inlay pieces not getting cut correctly.-20181003_151800-jpg
    any help would be appreciated.
    Attached Thumbnails Attached Thumbnails Problems with Inlay pieces not getting cut correctly.-20181003_151958-jpg   Problems with Inlay pieces not getting cut correctly.-20181003_151800-jpg
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Default Re: Problems with Inlay pieces not getting cut correctly.
    As far as I can see from your photo, you wood is breaking away. I guess that you are cutting too much material in the final pass.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
