VCarve Pro Patch 9.508
Results 1 to 4 of 4
Thread: VCarve Pro Patch 9.508
    Member GigaWatt's Avatar
    Apr 2015
    Default VCarve Pro Patch 9.508
    I noticed this morning when I started VCarve 9.5 there was a notice in the top right corner there is an update available 9.508. I clicked on the message and downloaded the update. The first time it failed to install properly. Tried again and it installed correctly.
    Now when I click on the shortcut it states "the file has been moved or no longer available". The only .exe file in the folder now is the Patch file.
    Oct 2016
    Netherlands
    Default Re: VCarve Pro Patch 9.508
    Update of your VCarve 9.5 did not go well.
    Reinstall VCarve 9.5 and overwrite the old installation..
    OR,
    Uninstal VCarve 9.5 and reinstall it.
    Try to update or never update it...
    Apr 2015
    Since I have 9.5 on my laptop and cnc computer, I decided to play a little last night. I removed 9.507 and then reinstalled it. I then applied the patch for 9.508. This time it installed properly and indicated I need to restart VCarve to complete the installation. Must have been a glitch in the process, it's working properly now. I believe Norton Antivirus may have contributed to the problem. I had Norton turned off on the last install.
    Oct 2016
    Netherlands
    Quote Originally Posted by GigaWatt View Post
    Perfect,
