cut depth issues with stl files -vcarve pro 9
Results 1 to 7 of 7
Thread: cut depth issues with stl files -vcarve pro 9
    May 2018
    Default cut depth issues with stl files -vcarve pro 9
    hey guys, i am very new to cnc and the software for it, i am having cut depth issues in a pocket on an stl i am using.
    my materials are .5" and im trying to cut the pocket .375" deep but often it shows on the cut preview that it will ony cut .125. i dont know how to manually set cut depth on a stl. all the cut details are generated by vcarve pro 9.
    i have attached some files and a picture if anyone can help.
    any and all help is much appreciated!!!!!
    thanks
    Attached Thumbnails Attached Thumbnails cut depth issues with stl files -vcarve pro 9-cut-depth-issues-jpg
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: cut depth issues with stl files -vcarve pro 9
    3D toolpaths cut deth should be to the bottom.
    There are two exceptions.
    1) If the tool won't fit in the pocket, it won't be ablt to cut the entire depth.
    2) If the vector boundary does not leave enough room for the tool around the edges, then it won't be able to cut the entire depth.
    You should learn to do this job using 3D vectors instead of from an .stl.
    The toolpaths will be much more efficient, resulting in cut times of probably 10x faster.
    And the finish will be much better.
    Attach your .stl and V Carve file (zip them).
    UCCNC 2017 Screenset
    May 2018
    awesome thank you, unfortunately with the stl i dont even see an option for cut depth, (unless its called something different). I will definitely try to use that file! do you mean attach those files here in the thread? or in vcarve pro? thanks a lot for your help!
    May 2018
    Quote Originally Posted by ger21 View Post
    where do i need to attach my stl and vcarve file to? this forum or in vcarve?
    thanks
    Mar 2003
    Shelby Township
    zip them and attach them here, and I'll take a look.
    Mar 2003
    Shelby Township
    There isn't a depth setting when doing roughing or finishing passes on an .stl (or any 3D model). The tool cuts down to the model.
  7. #7
    May 2018
    ok got you! here you go!
    Attached Files Attached Files
