A thesis paper is consist of three major parts, the front thing which includes abstract of the thesis, table of contents and acknowledgment, the middle part and the back thing which includes references, appendices, and glossary. The middle text part of the thesis is the most important which is usually divided into chapters and sections. To show the connection between the topics you will probably use the subheadings within the chapters. In the thesis, two main types of heading are used frequently. One using a decimal system and second signifying the levels of heading by variation in position, capitalization, and formatting. Each level of heading in the thesis paper should be clearly notable typographically from the other levels, and the variation should be used in the obvious hierarchy manner, means the top heading must look bold and important than the rest of the second and third headings. You can also take writing assistance from [url=https://www.gulfwriter.com/]thesis writing services UAE[/url] in order to get the perfectly written thesis paper with no format error.
