Wiring manual pulse generator directly to 2nd parallel port
Results 1 to 5 of 5
Thread: Wiring manual pulse generator directly to 2nd parallel port
    Member Michael82's Avatar
    Nov 2007
    Default Wiring manual pulse generator directly to 2nd parallel port
    Hello to all I am trying to add a manual pulse generator to my cnc router via parallel port. I installed a 2nd pci parallel port card to my pc and I have the pinout for the mpg. I just dont know how to get the 5v and 0v from the pc to the mpg here is the pinout and mpg I have
    Attached Thumbnails Attached Thumbnails Wiring manual pulse generator directly to 2nd parallel port-mpg-circuit-png   Wiring manual pulse generator directly to 2nd parallel port-screenshot_20191203-114856_chrome-jpg   Wiring manual pulse generator directly to 2nd parallel port-screenshot_20191210-143408_chrome-jpg
    Aug 2009
    Default Re: Wiring manual pulse generator directly to 2nd parallel port
    The disk drive power connectors in the PC will have +5v, +12v, and ground connections on it. You can get a drive power extension cable, clip off the side you don't need, and use that to gain access to the power lines you need.
    Nov 2007
    Quote Originally Posted by __Britt View Post
    Britt, thanks for the reply and ...wow I didnt even think to use the PC's board to get my power from.
    Nov 2007
    Hey britt can you post some pictures of the cable you are referring to so I will know which one to splice into
    Member john-100's Avatar
    Mar 2007
    uk
    you can connect to the red and black wires from a 4 pin MOLEX or 15 way SATA power cable
    Wiring manual pulse generator directly to 2nd parallel port-mpg-pulse-generator-4-pin-molex-jpg
    or
    a USB cable
    Wiring manual pulse generator directly to 2nd parallel port-usb-pinout-jpg
    John
