Where is Parallel Port?
Results 1 to 4 of 4
Thread: Where is Parallel Port?
    Jul 2010
    pak
    Default Where is Parallel Port?
    I have HP EliteBook 6930P, ECP Printer Port driver is installed in Device Manager. But there is not any printer port physically. Why this driver is installed, if there is not physical port.
    Jun 2005
    Default Re: Where is Parallel Port?
    Look under control panel then under ports. You can add pcmcia cards with an actual parallel port to some laptops.
    Russ
    Member CitizenOfDreams's Avatar
    Nov 2012
    The parallel port is in the docking station:
    Where is Parallel Port?-dst0472-3-600-jpg
    Attached Thumbnails Attached Thumbnails Where is Parallel Port?-188145-tier1-hp-docking-station-6910p-6930p
    Jan 2005
    If the computer has a ducking station port, the laptop will have to be placed on the docking station to physically access the parallel port. This is the most likely case with that computer.
    Edit. Got beat while typing
