M.RISHIKESH
SCSI is identified by the interface. IDE/SATA use pins and sockets whereas the SCSI uses a single slot type interface.
RFB
Dear Sir
We r aware about PC with IDE/SATA Harddisk
Please let us know how to identify SCSI capable PC as we have got a SCSI Harddisk in a machine and v need to take a clone of it in SCSI Capable PC
Regards,
M. Rishikesh
- Need Help!- SCSI Harddisk 45MB
- Need Help!- 50 Pin- SCSI HDD drive of capacity 45MB GE Fanuc Series 150M
- Need Help!- Communicating with 3-Axis Microarrayer Via SCSI
M.RISHIKESH
RFB
Buy a SCSI controller card. Most machines do not have SCSI built in to motherboard. Almost none do today. You'll need a free PCI slot.
this thermwood 9100 super controller has an old ega or cga video, (isa/eisa?) motherboard sockets (not PCI), and runs DOS 3.1 or 3.3, less than a 500MB SCSI 50-pin hard drive (which is going out and hard to find good ones) with what looks like a full-length server size scsi card with built-in floppy and serial ports.
i just want to make sure it's "safe" to plug in a standard SCSI ISA or EISA card (like adaptec 1520), only because this is such a proprietary board.
if this is just a standard board, i could probably also replace the ega or cga card with a vga ISA socket card. those old monitors are much more expensive and harder to find than a new vga monitor.
in the picture below, you can see the motherboard slots. the bottom socket LOOKS like ISA, the botthom and next small socket looks like 32-bit EISA?. then the mid and top socket of the single card socket are unknown to me. would plugging in a standard SCSI ISA card to the bottom slow work or is it supported? for IDE?
Your best bet would be to stop using that old hardware. If you can get all of your data out of that hard drive you can run it in any modern DOS system like FreeDOS. Make backups of everything!
FreeDOS | The FreeDOS Project
