Needing two 6061 spacers turned from 2.25 OD/ 1.75 ID tubing
I own and run a machine shop however we only manufacture our own products that we produce and sell directly. I need to get a couple extensions turned from 6061 and since our lathe wont accept a 2 inch diameter so I cant do it my self inhouse.
In the attached pdf file there are two parts, essentially the same part just two lengths.
I am looking to get one of each made for a total of two parts.
Machined surface tool finish is fine. Factory extruded surface finish on all non machined surfaces is fine.
Thanks in advance for your consideration. Please pm or email me at kdc754@gmail.com
Re: Needing two 6061 spacers turned from 2.25 OD/ 1.75 ID tubing
Hello,
Hope you are doing well!
This is Eva, Project Manager of Best Prototypes, a reputable prototype manufacturer in China. I am writing to see if there are any possible for us to be your supplier?
We have the services for your parts.
-CNC machining (3 axis. 4 axis. 5 axis).
-3D printing (SLA, SLM, 3DP,FDM).
-Vacuum Casting (silicone Mold),
-Fast Tool / Die casting.
-Machining (Bending,Punching,Cutting,Welding).
-Injection mold
If you have projects that need to quote, you can send it to my email, then attach the materials, quantity, process and finish you want.
I will give you a free quotation as soon as possible.
