Please email drawings and CAD models to: lee@elevatedmanufacturingsolutions.com and I will get back to you with a quote as soon as possible!
Thank you,
Lee Ort
Elevated Manufacturing Solutions
1-844-MFG-GURU
I'm looking for someone that can first do prototypes to make sure everything is good
Then do 5 to 10 piece runs. If you're familiar with guitars think of a Stratocaster just to get an idea
I will share drawings with someone that might be a good fit
Thank you,
Lee Ort
1-844-MFG-GURU
Hello, Toggle,
This is no problem,
I would need to verify the design model in 3D solids and generate Gcode.
Mcam or Fusion360
And I have choices of machines to run on.
Exotic, Torrified wood cuts easily. Those blanks must be expensive? Are you including any chambering?
We will need to discuss details like contour finishes, edge fillets, drill all holes, etc. and details like ownership of the data. Non-disclosure's are ok.
I have done many first proofs and prototypes, guitars and aircraft.
Looking forward to work with you.
Brian O.
brianostosh@ozztosh.com
Hello,
Hope you are doing well!
This is Eva, Project Manager of Best Prototypes, a reputable prototype manufacturer in China. I am writing to see if there are any possible for us to be your supplier?
We have the services for your parts.
-CNC machining (3 axis. 4 axis. 5 axis).
-3D printing (SLA, SLM, 3DP,FDM).
-Vacuum Casting (silicone Mold),
-Fast Tool / Die casting.
-Machining (Bending,Punching,Cutting,Welding).
-Injection mold
If you have projects that need to quote, you can send it to my email, then attach the materials, quantity, process and finish you want.
I will give you a free quotation as soon as possible.
Kind Regards,
Eva.
Email address: eva@best-prototypes.com
