RFQ 303ss Lathe parts
Results 1 to 3 of 3
Thread: RFQ 303ss Lathe parts
    Jan 2012
    Default RFQ 303ss Lathe parts
    Need a quote for 303 stainless steel pins.
    TF-001-2, 1/2" dia, 3-1/4" long: 12 ea
    TF-001-3, 3/8" dia, 2-1/8" long: 6 ea
    Just a start, there is more to come. We are a machining facility that has a lot of work attempting to build relationships with other machine shops and machinists interested in doing quality machine work
    of small quantities of precision parts and assemblies.
    https://productdesignsusa.com/
    charlie@products-designs.com
    Attached Files Attached Files
    Member JDLEnterprises's Avatar
    Jul 2021
    Default Re: RFQ 303ss Lathe parts
    Quote Originally Posted by machinster View Post
    Good Morning,
    I have recently purchased a CNC machine shop in San Bernardino and look forward to building relationships with other local shops as well. I just happened to have some 303 1/2" rod in my shop and made a quick sample for you. I was in a super rush and had a little adjusting to do but I dropped a sample off at your shop yesterday. Threads were GO 3414 and polished area was in spec. The largest dimension was already at the top of the material I already had in stock so I just left it for the sample.
    The previous owners made custom dental tools for almost 20 years but covid killed their only customer... Look forward to hearing from you.
    Shoot over your target price and I will let you know if I can help you out. It took us about 6-7 min with one operation, but I might want to do 2 operations because of the length etc.
    Thank you,
    JD
    Member Yinjiaru's Avatar
    Jun 2023
    Hello,
    Hope you are doing well!
    This is Eva, Project Manager of Best Prototypes, a reputable prototype manufacturer in China. I am writing to see if there are any possible for us to be your supplier?
    We have the services for your parts.
    -CNC machining (3 axis. 4 axis. 5 axis).
    -3D printing (SLA, SLM, 3DP,FDM).
    -Vacuum Casting (silicone Mold),
    -Fast Tool / Die casting.
    -Machining (Bending,Punching,Cutting,Welding).
    -Injection mold
    If you have projects that need to quote, you can send it to my email, then attach the materials, quantity, process and finish you want.
    I will give you a free quotation as soon as possible.
    Kind Regards,
    Eva.
    Email address: eva@best-prototypes.com
