RFQ - spindle screw for Delta lathe 46-715 Tailstock
Results 1 to 5 of 5
Thread: RFQ - spindle screw for Delta lathe 46-715 Tailstock
    Mar 2010
    Default RFQ - spindle screw for Delta lathe 46-715 Tailstock
    Just taking a stab here that someone might be able to make a spindle screw (#132) that is no longer available from the manufacturer for purchase, making the lathe useless. I would assume it's hardened and unfortunately I do not have a drawing of the part. The screw would need to be sent for duplication.
    Please let me know what information you would need to give me an idea of cost to reproduce.
    Thanks.
    Adam,
    Attached Thumbnails Attached Thumbnails RFQ - spindle screw for Delta lathe 46-715 Tailstock-snag-0456-jpg
    G540, Rack and Pinion Drives-X/Y axis, 1/2-Ball Screw-Z Axis w/THK HSR 25 Linear Slides, Steppers KL23H2100-35-4B, Power Supply-KL-600-48
    Oct 2009
    Default Re: RFQ - spindle screw for Delta lathe 46-715 Tailstock
    Hi Adam, your mbox is full...
    Mar 2010
    Project completed.
    Thanks,
    Oct 2009
    Smile Re: RFQ - spindle screw for Delta lathe 46-715 Tailstock
    Quote Originally Posted by adam_m View Post
    Project completed.
    Thanks,
    great - I had an idea ballpark $20...
    Oct 2009
    FYI to CNCZone Community - the ballpark $20 is a DIY solution (had to say that before somebody says I was posting a (Quote price)
