RFQ Water Jet or laser cut 3mm aluminum
Results 1 to 2 of 2
Thread: RFQ Water Jet or laser cut 3mm aluminum
    Default RFQ Water Jet or laser cut 3mm aluminum
    I'm prototyping a part and need to get a few brackets made. Basically it's ~ 1"x12", 18", 24", and 36" rectangles with nods cut into the ends. Would like to have a quick email discussion prior to sending art to ensure best use of material. Will probably need 5-10 of each length.
    Member konwey's Avatar
    May 2017
    China
    Default Re: RFQ Water Jet or laser cut 3mm aluminum
    Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
