I need Qty 4pcs 12" sq x 1/2" thick mild steel plates with simple hole pattern laser cut or waterjet per attached drawing. Message me if you'd like to quote.Similar Threads: RFQ - 1/4" mild steel plasma or waterjet RFQ - Laser or Water Cut 11 gauge mild steel RFQ - Laser or Water Cut 11 gauge mild steel Laser to cut 1mm Alu, mild steel, and aluminum Laser Cut / WaterJet Mild Steel Parts
View Tag Cloud
Forum Rules
