RFQ for brass parts. 16ea +/- o pcs.
Results 1 to 5 of 5
Thread: RFQ for brass parts. 16ea +/- o pcs.
    LAXrich's Avatar
    May 2020
    Default RFQ for brass parts. 16ea +/- o pcs.
    Looking for someone in the Los Angeles, CA area interested in doing 16 of these parts. See attached. Material is brass. Can be made from 1-3/8" bar stock. Dimensions are not super tight, just .xxx on diameters. Part is cosmetic so a decent finish is required for subsequent polishing and plating.
    I can't economically get the 1/16" radii on my 2-D mill on the tapers.
    CAD model on request if needed.
    Oct 2009
    Default Re: RFQ for brass parts. 16ea +/- o pcs.
    Sir could you post your contact email or enable private messaging - did the file attach?
    Thank you,
    Member cooperjm's Avatar
    Sep 2009
    We are near the other LA, Lower Alabama. If you could post the file we can send you a quote.
    Info@g28machining.com
    Apr 2012
    Looks like nothing attached.
    Member Cbolt22's Avatar
    May 2020
    Hello,
    We are located in Los Angeles and I'll be happy to quote if this opportunity is still available!
    Please send drawings to julian.revilleza@cbol.com
    Bests,
    Julian R.
    CBOL CORPORATION
    19850 Plummer St.
    Chatsworth, CA 91311
    TEL: (818) 721-5522
    FAX: (818) 459-7508
    Email: Julian.Revilleza@cbol.com
    Website: Just a moment...
