RFQ - CNC Small steel piece
Results 1 to 4 of 4
Thread: RFQ - CNC Small steel piece
    Jan 2014
    Default RFQ - CNC Small steel piece
    I have a part that I broke and need replaced. I'm sure it's not worth anyone's time, but it would be a life saver for me if someone could cnc this part in steel. Nothing fancy, regular run-of-the-mill steel should be fine, no tool steel or anything. I really appreciate it, step file and reference pictures are attached. Thank you!
    Attached Thumbnails Attached Thumbnails RFQ - CNC Small steel piece-screen-shot-2020-04-25-10-29-a   RFQ - CNC Small steel piece-screen-shot-2020-04-25-10-29-a
    Attached Files Attached Files
    Member jtshop's Avatar
    Feb 2018
    Default Re: RFQ - CNC Small steel piece
    Can you send step to jhkc2003@yahoo.com....I can't download yr step fine for some reason. Thanks.
    Sent from my SM-N975U1 using Tapatalk
    Hello, I would be interested in quoting this for you. My name is Jeff and I’m the owner of JCR Precision LLC based out of the Cleveland Ohio area. Would you be able to provide me with any tolerances you require?
    Member dipakpatel's Avatar
    May 2020
    Require Qty please?
