RFQ - Turned Steel Adapter
Results 1 to 2 of 2
Thread: RFQ - Turned Steel Adapter
    May 2007
    Default RFQ - Turned Steel Adapter
    Fairly simple turned steel part. Unfortunately I only need 1 piece of this in steel (any grade), so I realize price will reflect that some.
    The inner 2.5mm x 45° chamfer/taper is critical. The outer one is just an oversized edge break. There are a couple other important dimensions/tolerances.
    I've attached the drawing, and can provide 3D models if you'd want.
    PM or email me.
    Attached Files Attached Files
    Member cooperjm's Avatar
    Sep 2009
    Default Re: RFQ - Turned Steel Adapter
    Todd
    I have sent you an email.
    G28 Machining.com
    Mike Cooper
