Hi Stickr?
Can you give me your email or contact me? We can finish the work quickly. and price is my advantage
kon@plusminusthree.com/www.plusminusthree.com
I need 2 axle bushings made.It's a bushing to convert a Suzuki DR650 axle and make it compatible with Suzuki RMZ 450 shocks. I believe it should be made out of Stainless 304 or 316 but would rely on your recommendation. Please see drawing. Measurements are standard inch except for the inner threads which are 16x1.5mm internal threads.
Hi Stickr?
Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
You probably should list your location, somebody could be right in your backyard. You probably want to pick 316 for the increased corrosion resistance over 304.
Hi stickr!
We can manufacture this type of cnc turning job with 10 micron accuracy and 0.4 ra value surface finish.
You can visit our website for Credex Imagineering LLP | CNC Machining Component Service for more our cnc products.
Best regards,
Dhaval B. Goti
