Small die set needed DEEP 3d Quality Engraving Required
Results 1 to 2 of 2
Thread: Small die set needed DEEP 3d Quality Engraving Required
    Oct 2013
    Smile Small die set needed DEEP 3d Quality Engraving Required
    Small jewelry part die set needed.
    Requirements: must be able to do HIGH QUALITY 3D ENGRAVING WITH DEPTHS TO 12mm.
    I have a pdf of the SIMPLE die set
    it is designed on the KISS theory.
    Die set is made on 2 inch round d2, a2 or s7 steel.
    female die & male die have the same engraving
    there is a nesting/resting area on the female die to hold the
    round material disc.
    I supply a HIGH DETAILED QUALITY STL FILE FOR THE ENGRAVING.....
    engraving would be 12mm in diameter & 6mm depth for the first die set.
    I HAVE A PDF FILE FOR THE DIE SET.......too large file here to load
    can email you the file to view.
    If anyone knows of a person or company capable of doing this please
    let me know roger@revoked.com
    Member awerby's Avatar
    Apr 2004
    Default Re: Small die set needed DEEP 3d Quality Engraving Required
    Did you want someone to engrave something into your dies, so that the engraving would transfer to a piece of gold or silver when the die was used? That would be a stamping operation; engraving is done directly onto the precious metal. Dies are typically used for punching out shapes; if you wanted to put a raised or lowered design into the precious metal sheet, that would require a stamp. Engraving is normally quite a bit shallower than 6mm as well.
