PM sent...Pls check your inbox
I need this for a simple mock up job. Either Laser Cut or probably better would be waterjet from steel plate, or CNC from thicker Aluminum. I just need it to be stiff enough to make sure my dimensions and stuff are correct, so I think 3/16" Plate (maybe even 1/8") or 1/4" Aluminum would be fine.
Units are mm, the lower holes are 192mm apart, the closer ones are 140mm apart, and they're 8.5mm offset.
I need 1 piece for sure, maybe 2 depending on cost.
Message me here, or post here. Need these sooner than later.
PM sent
Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
RFQ is now closed. It has been awarded.
Thank you to all those who quoted.
