RFQ Sheet Metal Assembly
Results 1 to 3 of 3
Thread: RFQ Sheet Metal Assembly
    Apr 2013
    Default RFQ Sheet Metal Assembly
    Hello
    **EDIT - I don't need it to be assembled, just need the parts punched/broke
    I'm looking to make 10 sets of the parts for this assembly as shown.
    Material is 12 ga steel
    All the parts are/were punched on a Turret Press, 3 of the parts require edges to be bent as seen.
    The main housing is approx 17.5 x15 x 3 inches
    Finish is grey textured powdercoat on all sides of all parts (though could be slightly flexible to different types of powdercoat)
    I have drawings, dxf and solid models of all the parts available.
    Location is North Texas in ZIP 76301
    Thank you for your time.
    RFQ Sheet Metal Assembly-sheetmetalassy-jpg
    Member konwey's Avatar
    May 2017
    China
    Default Re: RFQ Sheet Metal Assembly
    Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
    Apr 2013
    Closed..please delete
