You seem to have private messaging turned off.
What software did you use to generate the file, AutoCAD won't open it and Fusion brings it in as a point cloud. Do you have a .step or iges file?
Hello,
The project I am currently working on is a protective slider for an engine cover on a 2006-19 Yamaha R6 motorcycle, and I am looking for a manufacturer that can complete the work. The first order will most likely be 50 units CNC machined from 6061 aluminum, with subsequent orders to follow. Tolerances don't need to be particularly strict, +/-0.5 mm should be fine. I realize that there are several sharp interior corners on this model (See attached) that will need to be radiused, so if need be just let me know the minimum radius you need and I will update the model. For the finish I would like to have 25 units in anodized black, and 25 units in anodized gold, keep in mind that it needs to be resistant to fading because some of the customers motorcycles are kept outside 24/7. If you need a different CAD file format, just let me know and i'll make it happen. If you are interested, would like more info, or have any input for me just let me know!
Thanks!
Jim Dawson
Sandy, Oregon, USA
Can you send step or soliworks or parasolid file? coronal08@yahoo.com
Thanks.
Sorry about that, private messaging should be on now.
I created the file with Rhino 6, I haven't had any luck uploading anything other than .dwg and .dxf on here but I can send you a step or iges file via email if that would be better for you.
Could you send an .igs to gary@icdproducts.com ? We have loads of experience making side covers, this would dovetail into our production nicely.
Thanks in advance,
Gary
We look forward to that, Ted. In addition to our extensive contract manufacturing experience (35 years) we enjoy designing and manufacturing our own lines of merchandise, mostly in the adventure sports market (shooting sports, paintball, and motocross accessories mainly have been our focus) as that is what we spend our free time enjoying. We do a lot of custom work in the same field as well, racers and hotrod builders always seem to sniff us out! Looking forward, always! Thanks for sending over the files, our best man is on it as I type this- Gary
