2 Aluminum or Stainless Panels
Results 1 to 6 of 6
Thread: 2 Aluminum or Stainless Panels
    Nov 2017
    Default 2 Aluminum or Stainless Panels
    Personal project - I need one of each of these panels made in aluminum or stainless ~2 mm thick (~.078"). Parts are 7.5" x 5" and 6" x 3". Previews below, the tolerances are not that critical, really anything more than just hand cutting will do. Small inside corner rads are fine, I can file to fit. I do have CAD files and can convert to whatever is needed. Smallest hole size is ~.125" in either case.
    2 Aluminum or Stainless Panels-computer-panel-preview-jpg
    2 Aluminum or Stainless Panels-mill-panel-preview-jpg
    Attached Thumbnails Attached Thumbnails 2 Aluminum or Stainless Panels-computer-panel-preview-jpg   2 Aluminum or Stainless Panels-mill-panel-preview-jpg
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: 2 Aluminum or Stainless Panels
    There will be a laser cutter nearby you that can do this easily - Peter
    Nov 2017
    Yeah, I have tried a few places and they either won't do personal projects (I've been told for tax reasons they can't work for individuals - not sure I believe that but whatever) or they don't bother with one offs usually because the cost for it will be too high. And I have gotten some quotes that are way too high for what I need in these parts. Figured I would check on here if anyone wanted a go.
    Member cooperjm's Avatar
    Sep 2009
    Send the dxf to Mike@g28machining.com
    Sent from my SM-G955U using Tapatalk
    Member CROSSHATCH's Avatar
    Sep 2006
    Can't private message through my phone (oh well).
    Can you e-mail at crosshatchengineering@gmail.com
    I'll provide a quote via e-mail, along with any other comments or questions.
    Regards,
    Jason
    Member jtshop's Avatar
    Feb 2018
    i sent you private message...pls let me know. Thanks
