- 2 brass pieces milled
Hi
Personal project - I need small two sculptural shapes milled out of brass. maybe best done in 5 axis.
- Needs to be delivered to Brooklyn for the Monday the 25th.
- they are prototypes and the stock dimensions can change slightly if needed.
Currently drawn to 3 x 4 x 6 inch pieces of brass stock.
- The bases would be clamped for milling then ground off. I have drawn these as separate components in the file.
link below:
https://a360.co/2SZTNrC
Thanks for the quotes,
Tony
- You may not post replies
- You may not edit your posts
Forum Rules
