Aluminum plates with countersink holes
Results 1 to 10 of 10
Thread: Aluminum plates with countersink holes
    Feb 2018
    Default Aluminum plates with countersink holes
    I need 50 of these plates to start with as soon as possible. I should be needing more of these and a couple of different variations soon after. If possible I would like them in a black finish, but I can get them finished locally if it would be too much of a delay. This is a finished part, so I need smooth edges.
    5.15 x .250 in 6061 Aluminum Plate
    .35 in holes and slots
    Holes need countersink to .60 in wide.
    No rough edges (give me options)
    50 parts with more to follow
    Black finish preferred.
    Quote raw & black finish if possible.
    Thank you.
    Attached Files Attached Files
    Registered cooperjm's Avatar
    Sep 2009
    Default Re: Aluminum plates with countersink holes
    What type of black finish are you referring to? What kind of tolerances do you require?
    G28Machining.com
    G28machining@gmail.com
    Sent from my SM-G955U using Tapatalk
    Feb 2018
    I’m looking at either a gloss black powder coat or a black anodized finish. I’m open to suggestions.
    Im thinking +/- .005. Its a pretty basic bracket to bolt two parts together.
    Sep 2009
    Ok, I will put a quote together for you.
    May 2015
    Pm Sent.
    Thanks, Matt Mittler
    Mittler Machine Works
    matt@mittlermachineworks.com
    Cnc Machining | Newmarket | Mittler Machine Works
    Registered konwey's Avatar
    May 2017
    China
    PM sent
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:kon@plusminusthree.com
  7. #7
    Jan 2008
    PM sent.
  8. #8
    Registered Attilka's Avatar
    Nov 2011
    PM sent.
    Thanks,*
    Attila*Kovacs*
    Supreme Leader*
    206-669-3524*
    attila@birchmfg.com*
    3400 N Arizona Ave Ste 110*
    Chandler, AZ 85225*
    Sent from my MHA-L29 using Tapatalk
  9. #9
    May 2018
    China
    PM sent
  10. #10
    Feb 2018
    This job has been awarded. Thanks.
