Originally Posted by
txcncman
No clue. I ditched the quoting when you said it was awarded. Since you are costing the material for your supplier, did you include the delivery charge too? It really is not that big of a deal to me. As I said earlier, this turned into more of an opportunity to attempt educate about the RFQ needs on tolerances and specifications. We have gone back and forth now about 3 times, and I still am not sure if you want the 0.875" diameter at +/-0.015" tolerance and if you meant 0.125" radii for fillets also applied to the outside corners as well. Most of the time, hole diameter tolerances are held slightly close than linear tolerances.
