- Stepper Driver Board
*Registered User*
Hi All ... looking for some advice from the technically advanced here. I have a CNC Shark Pro from Next Wave Automation. The machine has been awesome. Recently I replaced the stepper motors and the direction of travel was reversed on all of them. I took some bad advice and switched some wires to reverse it and fried the driver board. I've since learned you can make the changes in the software. Problem is the driver board is no longer made so I have to replace it with something different. Wondering if anyone can recommend one? 3 axis, power supply is 24V 6.5amp. I'm not an electronics guy, just a simple cabinetmaker but I really miss this machine, it has served me so well for the past 7 years. Any help or recommendations would be greatly appreciated. Thanks in advance
Re: Stepper Driver Board
The best way is to contact to manufacturer.
if not I can change the controller to new one.
email me mattcnc@protonmail.com
- You may not post replies
- You may not edit your posts
Forum Rules
