NEED HELP WITH A CHINESE CNC ROUTER 1325 WITH THE CONFIG IN MACH3
Results 1 to 2 of 2
Thread: NEED HELP WITH A CHINESE CNC ROUTER 1325 WITH THE CONFIG IN MACH3
    Feb 2017
    Mexico
    Default NEED HELP WITH A CHINESE CNC ROUTER 1325 WITH THE CONFIG IN MACH3
    Hi guys, first of all sorry for the bother but im a newbie in this of the cnc world and it happen that i had acces tpo a cnc router from china, the provider send me a xml file to load to mach 3 but the config was wrong and the machine doesnt perform well, the first problem that i had was that when i load a g code, i use vcqarve, the machine do the job but like ten times larger than the orignal size when i load a g code in mm and 1/3 of the original size when i load in iches, the machine is set in mm, i fix that problem using the step per unit tool in the settings tab, then the z axis was working in reverse so i change from set low to direct low in the pot and pins tab in motor output but when i do all that to fix the machine the jog speed reduce way down, like 20% of his speed also if i hit go to zero button it does like 20% of the speed, i really cant find the answer that why i asking for help
    Any help would be very much appreciated i attach some pics of the motor tuning and a link to videos of the jog speed of the machine, the original movement and the movement left after the changes
    h
    jog speed fine
    jog speed after the changes
    Attached Thumbnails Attached Thumbnails NEED HELP WITH A CHINESE CNC ROUTER 1325 WITH THE CONFIG IN MACH3-x-axis-gporthos-jpg   NEED HELP WITH A CHINESE CNC ROUTER 1325 WITH THE CONFIG IN MACH3-y-axis-gporthos-jpg   NEED HELP WITH A CHINESE CNC ROUTER 1325 WITH THE CONFIG IN MACH3-z-axis-gporthos-jpg
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: NEED HELP WITH A CHINESE CNC ROUTER 1325 WITH THE CONFIG IN MACH3
    Ok right now it`s in 2000 FRO, can you post here the factory specification of the machine? if possible can you post here your MACH3mil XML file so that we can take a glance on all the settings and compare or correct it to the manufacturer`s optimum specification
    It really differs from one machine to the other, depends on your hardware optimum speeds. so fine tuning it will be a must. right now you`re on a fine tuning stage. next is overclocking hehehe just joking
