Hi Guys, I figured it out. When using feed rate in the gcode you have to have the fall down set to 1 to utilize the full speed of the gcode feed rate. This is why mine wasn't reading the correct feed rate. What made it more confusing is my machine is set to have it's slowest Z axis feedrate to 100mm so it wasn't showing 10% of 254 and that made me even more confused. Thanks for the help, Hopefully this helps someone else.
