A lot of deflection on belt driven CnC, better belts?
Results 1 to 2 of 2
Thread: A lot of deflection on belt driven CnC, better belts?
    Member brianhatley's Avatar
    Mar 2020
    Default A lot of deflection on belt driven CnC, better belts?
    Hey guys, I have a zenbot4896 Cnc router that uses belts as the drive system, well they are very flexible, and I don’t want to tension them anymore then they are because I’ve already broke a shaft off of one motor.
    Are there better, tougher belts that I could replace them with? I eventually play on converting to a rack and pinion setup, in just not there yet.
    Thanks in advance!
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: A lot of deflection on belt driven CnC, better belts?
    Yes, there are, but you still need to tension them a LOT, which will lead to more broken shafts. What you need are much larger belts, that likely won't even work without a redesign. I would say something at least 2" wide, although ideally it would be even wider. Belts will always stretch, and the longer they are, the more they stretch.
    UCCNC 2017 Screenset
