Hot rolled steel isn't very flat to start with. Cutting a slab of it into pieces with a plasma cutter isn't going to help with that. But any surfaces you intend to mount rails to need to be extremely flat. Are you taking the rough assembly out for heat-treating and then having someone machine it flat? Or did you have some other plan that would make this work?
