Hi all,
I have purchased a new CNC-Router with clamping area of 1730x890mm (weight: 82 kg - picture attached) , and I was wondering what do you recommend to use as the "structure" or table. What is the normal way to use this kind of CNC-Routers? Does it work well on top of a standard table, or is it better to have a stainless steel structure?
Many thanks
Mactec54
As long as the table is solid and it holds the machine level it shouldn't make a huge difference what the material is.All he cutting forces are contained by the machine itself but you will need a bit of diagonal bracing to reduce the vibrations in response to movement of the gantry as any oscillations could combine with the harmonics of the gantry with extreme accelerations or decelerations.Stainless would work well but you would need to find an amazing deal given how inexpensive steel is.
With a machine like that, the table really adds nothing to the machine. Any flat surface that will hold it still will be fine.
UCCNC 2017 Screenset
