CNC Router - Frame Structure
Results 1 to 4 of 4
Thread: CNC Router - Frame Structure
    Member gmoreno_cnc's Avatar
    Dec 2019
    Default CNC Router - Frame Structure
    Hi all,
    I have purchased a new CNC-Router with clamping area of 1730x890mm (weight: 82 kg - picture attached) , and I was wondering what do you recommend to use as the "structure" or table. What is the normal way to use this kind of CNC-Routers? Does it work well on top of a standard table, or is it better to have a stainless steel structure?
    Many thanks
    Attached Thumbnails Attached Thumbnails CNC Router - Frame Structure-cnc_router_high_z_s_1000t-1-jpg
    Member mactec54's Avatar
    Jan 2005
    Default Re: CNC Router - Frame Structure
    Quote Originally Posted by gmoreno_cnc View Post
    Hi all,
    Many thanks
    Some build a wooden table to support there machines needs to be quite solid though, a steel frame is always going to be best but needs to be well built also, stainless steel material is not needed but if it is at a good price then why not
    Mactec54
    Member routalot's Avatar
    Dec 2003
    As long as the table is solid and it holds the machine level it shouldn't make a huge difference what the material is.All he cutting forces are contained by the machine itself but you will need a bit of diagonal bracing to reduce the vibrations in response to movement of the gantry as any oscillations could combine with the harmonics of the gantry with extreme accelerations or decelerations.Stainless would work well but you would need to find an amazing deal given how inexpensive steel is.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    With a machine like that, the table really adds nothing to the machine. Any flat surface that will hold it still will be fine.
    UCCNC 2017 Screenset
