Hello, we've had trouble with lubrication errors and service personnel had to remove belt from Y axis and manually (by hand) rotate ballscrew and after returning belt the Y axis was no longer correct, meaning when you have to drill a hole in Y10. coordinate it would drill it in Y19. How do you fix this problem in machine parameters or somehow without removing belt again and trying to get the ballscrew back to it's original position?
