New Machine Build DIY Large Sheet Cutting Machine
Results 1 to 4 of 4
Thread: DIY Large Sheet Cutting Machine
    Apr 2009
    Greece
    Default DIY Large Sheet Cutting Machine
    Hi guys,
    I have built my first CNC machine 4 years ago and hopefully it still works.
    Now what I am wondering about is if I could be able to built a large sheet cutting machine for melamine and MDF sheets. I am not interested in building the hydraulics that pull and push the sheets, but mainly I need to know how I could built the base of it, then put the moving cutting blade machanism under the machine and finally connect it with linear guide attached to a motor with a driver.
    Any ideas if this idea can be implemented and if there is any trader that sells moving cutting blades would be really appreciated.
    Thanks in advance.
    Member awerby's Avatar
    Apr 2004
    Default Re: DIY Large Sheet Cutting Machine
    Are you talking about a moving table-saw blade, or a router of some sort?
    Apr 2009
    Greece
    Quote Originally Posted by awerby View Post
    I am talking about a moving saw blade, just like the moving blade in the large sheet cutting machines.
    Thanks.
    Apr 2018
    So a DIY Beam Saw?
