You can eliminate the 3030 cross pieces at the cost of table rigidity. There are a lot of builds out there that have done just that. If you are going to be cutting plywood, you can get away with eliminating some of the cross braces.
On the linear rails:
Quality rails are expensive and I would not go with anything less than 35mm square rails. But keep in mind that much of the design would have to be changed.
