The error is most likely in the setup or layout in your CAM program. Specifically, the location of your dowel holes.
I haven’t used my homemade machine in a while but I’m about to get back work on a the project that I had trouble with in the past. Does anyone know what wi cause offset error when cutting a 3D part using the part flip method. I used 2 dowel pins and reference holes in my part stock material. I think it may be lost steps or acne backlash error but I’m not sure. My part cuts perfect on each side as far as I can tell but is offset by roughly 3/16” in each side only in one axis, the longest dimension of the part.
I’m using 4 start acme screws, plastic backlash nuts, stepper motors, Mach 4. The machine structure is metal and pretty solid but something is going on and I’m kind of stuck. The part I’m cutting takes a long time to cut and is a long g code program. Also, the offset error does vary from part to part but is always present.
Any ideas? Thanks
UCCNC 2017 Screenset
Have you tried reducing the feed and rapid speeds? That should help to indicate if it's missed steps.
If you've got 3/16" of backlash, you would have other severe issues..
You could try putting marks on your couplers and shafts and see if the marks still line up the same way when you flip the part and when you're done.
How much variation in the offset are you seeing? If it's minor compared to the 3/16" or so total error, it may be you've got a CAD/CAM issue as well as a mechanical issue.
