Hey. I'm new here so not sure where to post my question. Thanks to all who help.
Here's the problem. While profiling (using Mach 3) the Z Axis on my Machine progressively goes deeper at certain points. I'm watched the Z Axis move very slightly and stopped to check the code for error. Here's the Code that's causing the problem:
N204160G1X4.7125Y0.6326
N204170G1X4.6763Y0.6509
N204180G1X4.6390Y0.6685
N204190G1X4.6008Y0.6855
N204200G1X4.5621Y0.7016
N204210G1X4.5232Y0.7171
N204220G1X4.4842Y0.7317
N204230G1X4.4454Y0.7456
N204240G1X4.4071Y0.7587
N204250G1X4.3337Y0.7822
N204260G1X4.2661Y0.8020
N204270G3X4.2158Y0.7671I-0.0111J-0.0378
N204280G1X4.1690Y0.1229
N204290G3X4.1774Y0.0957I0.0393J-0.0028
N204300G1X4.1806Y0.0916
N204310G1X4.1821Y0.0893
N204320G1X4.1831Y0.0873
N204330G1X4.1838Y0.0855
N204340G1X4.1842Y0.0840
N204350G1X4.1844Y0.0825
N204360G1X4.1844Y0.0811
My guess is it's happening on the J- Commands. There's are dog-bone fillets at the 2 J commands, and it looks like the Z Axis starts dropping just after the first fillet up to the second fillet. Just past that code is the point where the next cut in starts, so the Z Axis goes deeper, but then it goes to deep because it already dropped off before. Oh I should also mention that the area between the 2 fillets are curved.
I've also noticed this progressive deepening of the Z Axis on another job profiling circles. It seems like curves cause the Z Axis to drop slowly, so next time a plunge comes around, it plunges way to deep. I hope all this makes sense?
Is the Z axis DRO showing the position change?
UCCNC 2017 Screenset
I'm a complete noob so not sure what DRO is
But it's not specified in the GCode to move the Z-Axis, and it doesn't show in mach 3 when looking at the units. If I zero the Z axis from there it's out by 0.1 units, sometimes more, depending on how big the circle is. (whatever a unit is in mach 3, haven't manged to set it up so a unit shows in mm).
Sometimes it happens because of "spring", if your machine is not rigid enough. As you start, the axes are moving faster than the tool can cut so it springs. Then as it ends a profile or has to go around a sharp turn it slows down, which increases the amount of "cuts" if you will of the spindle over a certain distance, which allows it to dig deeper into the material.
You can try running the program slower, or set the accel a little slower, or raise the spindle speed to see if that helps. You can run the program, then re-run it to see if it removes any depth change. Then you'd know you have to beef up one or more of the axes.
resolved my issue blogger at : https://ptclbill.net/ptcl-speed-test/
I also have the issue someone please take a look. https://fescobill.pk/fesco-duplicate-bill/
