They arrived , Gerber Dimension 200 e times 2 . - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: They arrived , Gerber Dimension 200 e times 2 .
  1. #21
    Registered Kru82's Avatar
    Feb 2014
    Usa
    Default Re: They arrived , Gerber Dimension 200 e times 2 .
    A few pics of the system test . You tell me if this is looking pretty darn good so far .
    They arrived , Gerber Dimension 200 e  times 2 .-img_20150406_221831-jpgThey arrived , Gerber Dimension 200 e  times 2 .-img_20150406_221901-jpgThey arrived , Gerber Dimension 200 e  times 2 .-img_20150406_221914-jpgThey arrived , Gerber Dimension 200 e  times 2 .-img_20150406_221928-jpg
  2. #22
    Feb 2014
    Usa
    Electronics ( motors ) are up and running . Slightly tuned till they are mounted back on the machine . Still no major glitches so far . Need to calibrate for the size of lead screws Gerber has on them yet .
    Should have at the end of it all 2 spare Gerber control boxes , that I don't see myself ever using .
  3. #23
    Feb 2014
    Usa
    One machine put back together and motors mounted , tuned better and on the stand . Screws calibrated and velocities i am okay with . Some cable management to do and grease all the screws , directions need to all be reversed as per the Mach jog screen settings , but those vids I know I have seen . Just forgot to save the link . New bearings should be shopped for next week . Since the gantry height is only 2.25 inches off the table , plenty of room to cut the extension side plates 1/2 to 5/8 thick alum . New riser blocks under the existing gantry only needs four holes drilled on each and longer bolts for them . Figure adding just another 3 inches to height for now for a 5.25 clearance , some table material clamps to go also . Coming together quite well . Still have to do a spindle / router mount too ,
    All of you have helped through your threads with issues you had to deal with , Thanks sincerely .
    Machine 2 should be no issue .
  4. #24
    Feb 2014
    Usa
    Did the first test cuts today and the machine with the swap out of electronics has had a few weird happenings but all in all I am pleased . ( that motor hum that some have had through a previous post when in idle mode ) They arrived , Gerber Dimension 200 e  times 2 .-img_20150412_133249-jpgThey arrived , Gerber Dimension 200 e  times 2 .-img_20150412_140834-jpg
  5. #25
    Feb 2014
    Usa
    It has been close to 2 weeks and all is well with the electronics swap out . Getting closer to the spindle choice to be completed , but for the hand trimmer used it hasn't given any problems as of yet and I think it is coming close to being on it's last legs . No loss in steps and circles are circles when cut . They arrived , Gerber Dimension 200 e  times 2 .-img_20150421_141450-1-jpg
    When the spindle choice is made , then should be looking at doing some aluminium .
  6. #26
    Feb 2014
    Usa
    G540 , cables and motors arrived today to swap over the second machine . Will be nice to get it going as well .
  7. #27
    Feb 2014
    Usa
    Some of the items having a ball with . They arrived , Gerber Dimension 200 e  times 2 .-img_20150601_152736-1-jpgThey arrived , Gerber Dimension 200 e  times 2 .-jpgThey arrived , Gerber Dimension 200 e  times 2 .-death_dealer_black_and_white_by_tomg0-jpgThey arrived , Gerber Dimension 200 e  times 2 .-speakeasy-final-image-jpgThey arrived , Gerber Dimension 200 e  times 2 .-tttt-jpgThey arrived , Gerber Dimension 200 e  times 2 .-pom-male-jpgThey arrived , Gerber Dimension 200 e  times 2 .-img_20150531_172140-jpgThey arrived , Gerber Dimension 200 e  times 2 .-steam-2-jpg
  8. #28
    Oct 2019
    Hey Kru82. Would you have any extra components you would like to get rid of? I have recently come into possession of one but I’m missing items needed to get this thing operational.
  9. #29
    Member jtagen's Avatar
    Dec 2019
    Quote Originally Posted by Gisseppi View Post
    If you're still looking for parts, I have a full working controller for a Dimension 200 that I no longer need.
  10. #30
    Jul 2017
    [Hi
    Need advice...my neighbor wants to sell me a 2o yr old gerber dimension 200 with engtaving head and router and about 25 cutters.....in working cond.for 600$... is that a good deal?...
    OTE=Kru82;1675256]Y axis continued , pics . The compression spring end of lead screw is inset roughly 1 3/8 inch or 34 mm
    Attachment 274482Attachment 274484Attachment 274486Attachment 274488Attachment 274490Attachment 274492Attachment 274494Attachment 274496Attachment 274500Attachment 274502[/QUOTE]
