Z axis is going crazy! "Mach Blue screenset"
Results 1 to 7 of 7
Thread: Z axis is going crazy! "Mach Blue screenset"
    Mar 2011
    Default Z axis is going crazy! "Mach Blue screenset"
    I've been using my Zen 12x 12 with Mach 3 for a while now with no issues. All of the sudden I'm running into issues where the Z axis wants to go the wrong direction at times.... One specific time it does this is during the Z axis calibration (Z- button). I'm using the "MachBlue - probing big tex ver3.2" screenset that has the touch test on the Program Run screen.
    I actually think my problems started when I tried to run the "Initial Zero Setup" script found on the Program Run screen. It did not want to work correctly (reversed Z axis) so I stopped it. ever since then I've had problems with the Z axis going crazy. It would go threw the calibration touching the plate, going up a bit then down slowly till it touched again, and instead of going Up as it should it plummets down into my touch plate!
    Has anyone ran into this type of issue before? If so please help me get my machine behaving correctly again!
    It seems as though I can cut some stuff when I manually zero the Z axis but just a minute ago I tried cutting a piece and 1/2 way threw the Z decided to bore all the way strait down... The DRO actually changes to a much higher positive number making the machine think it is way high when its not. I'm cutting slow so its not a skipped steps issue... What is going on!
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I had an issue when I tried to home my Z axis, instead of moving toward the switch, it would move 1" away from the switch.
    I had to create a new profile from scratch to get it working correctly again.
    UCCNC 2017 Screenset
    Mar 2011
    I would be willing to give this a try if I only knew how to do it. Where do I create a new profile in Mach3?
    Mar 2003
    Shelby Township
    Double click on the Mach3 loader icon, or Mach3.exe from explorer.
    Mar 2011
    Quote Originally Posted by ger21 View Post
    Well that was easy enough. Before getting your reply I tried using the restore function. Went back to spots and the calibration thing seems to be fixed. I couldn't test the cutting part out to well because I'm trying to cut some 3/8" plastic cutting board (Building a 24" x 48" machine) but my bit keeps melting the material ruining the piece every time... I'm currently using a 1.8mm end mill. It seems to go longer without clogging at slower spindle speeds but it still clogs eventually... Maybe a larger bit? I should start a new thread but if anyone has any suggestions for the cutting issue it would be appreciated as well
    Member dustmakernc's Avatar
    Dec 2020
    Default Re: Z axis is going crazy! "Mach Blue screenset"
    Quote Originally Posted by Claytonc View Post
    you need to increase chip load: decrease spindle speed, increase travel speed, change to larger diameter endmill, endmill with fewer flutes. Or some combination of the above.
  7. #7
    Member routalot's Avatar
    Dec 2003
    After nine and a half years,he might have figured it out.Or found other interests.
