Hitachi Seiki Service and Support!!!!!!!!1 - Page 9
Page 9 of 9 FirstFirst ... 6789
Results 161 to 176 of 176
Thread: Hitachi Seiki Service and Support!!!!!!!!1
  1. #161
    Apr 2011
    Romania
    Default Re: Hitachi Seiki Service and Support!!!!!!!!1
    Helllo guys i just got a Seiki Seicos my2 and i have some smalll problems . My machine had 5 axis some time ago . Some one stole the 4x5 axis from the machine and cut the wire . I have managed to get the wires out . started the machine and i need some how to get out the 4x5 axis from the software so i can work with the machine in 3 axis as i want . Did some one have made this modification ? Hitachi Seiki Service and Support!!!!!!!!1-image-16-12-16-06-56-1-aHitachi Seiki Service and Support!!!!!!!!1-image-16-12-16-06-56-jpeg i have fix the hard limit . I cant find in the manual how to get out the extra axis .
  2. #162
    Feb 2016
    Viet Nam
    Hello,
    I have the machine hitachi seiki VK 55II with seico 10 control. and now I can't reset the alarm [742] Editing the program. Does any one know how to fix this alarm. I need your helps.
    Thank you!
  3. #163
    Jun 2015
    Quote Originally Posted by riotmfg View Post
    Any idea where these thermal overloads are? I have looked everywhere, reset all breakers I could find but am still getting the AL-3 Thermal Alarm.
    I managed to clear the lube alarm by cleaning up the sensor in the lube reservoir. PLEASE help, I need to get this thing running.
    -Madison
    I dont usually do a necroposting, but in my case - all thermal overlaod alarms were due broken fan at the back of the control panel
  4. #164
    Sep 2009
    Macedonia
    Default Re: Hitachi Man
    Hi!
    We have a big problem on a machine HITACHI SEIKI VM40 with SEICOS M2 control, year 1988, SN No:40309,
    the machine was working just fine until the battery alarm appeared on the screen 033 BATTERY ALARM
    the both batteries were changed while the machine was powered off (unfortunately big mistake)
    on the screen we had:
    at first BUBBLE READ
    and then after a few seconds
    PC NOT READY
    SEICOS
    mark 2
    when we press NC/PC and then IINPUT the messages on the screen are:
    SUM CHECK ERROR SEQUENCER NOT READY
    BATTERY ALARM PLEASE CHANGE
    We found some procedure for overcoming this status on the machine
    the procedure that we conduct it is:
    1. Press F1(SEQUENCE) ->Press F2(DATASET) -> Press F4(TABLE) -> You will see “Constance Byte Table 1
    2. Type 0 0 (in the 1. 00) -> Press INPUT -> You will see Parameter Write Enable SW On ---------------
    3. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
    4. Press F6(END). -> You will see Write Enable SW Off
    5. Turn off WRITE ENABLE SW
    6. Press F6(END) -> Press F1(SEQUENCE) ->Press F3(PROGRAM) -> You will see Parameter Write Enable SW On
    7. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
    8. You will see top line of ladder automatically
    9. Press F2(ALTER) -> You will see ___(Cursor) on screen.
    10. Press F4(STORE) -> Press INPUT.
    11. Press F6(END) -> You will see Write Enable SW Off
    12. Turn off WRITE ENABLE SW
    13. Turn off NC power -> Turn on NC power
    After we did the procedure, we turn on the machine and we get Z80 CPU ALARM on the screen any suggestions how to continue from here?!?!
    We are asking a confirmation did we apply the right procedure?
    and after this we are assuming that the parameters should be loaded
    we have a backup of the original parameters,
    but if we need to load anything else please advise,
    If this is not the right procedure please let us know
    and point us for the right procedure in step by step if possible,
    We don't have any experience with this machine or this control so any suggestion is more than welcome,
    Thank you all in advance,
    Regards,
  5. #165
    sedi66's Avatar
    Jan 2018
    san luis potosi
    i need electric drawing hitachi seiki va 45 fanuc 11m can you help me
  6. #166
    Sep 2014
    Quote Originally Posted by sedi66 View Post
    Dear friends
    I need operation manual, wiring diagram, for a 5NE-1100 hitachi seiki lathe 1980 with fanuc 6T control
    thanks
  7. #167
    Member Florsita3's Avatar
    Feb 2019
    Quote Originally Posted by Hitachi_man View Post
    Hello all out there lost in the confusion of trying to find support for your Hitachi Seiki machines. I own a CNC Service Company in Wichita Kansas working on all brands of machines, but specializing in Hitachi Seiki. I currently have over 10 gig of info on Hitachi Seiki machines in my database from machine software to procedures and ELECTRICAL MANUALS!!!!! I have years of experience working with these machines, and until June of 04 I worked for Mori Seiki in LA as the Hitachi Seiki specialist. We DO travel, and my hourly rate for shop labor is only $75.00 per hour no matter what state your in. I also do phone support and provide procedures at $45.00 per hour 1 hour min....If you have a Hitachi Seiki machine, other machine models welcome also, call us and we will be happy to help!!! (cureing your headaches is free!!)
    You can contact us at 316-744-0549 just ask for Josh, aka Hitachi_man
    well be looking forward to hearing from you!!!
    HELLO
    I looking for DOCUMENTATION CS20/25 SEIKOS 21i TA (with motor and BETA DRIVE TURRET) with alarm 1020. Regards
  8. #168
    Member Dancy's Avatar
    Aug 2007
    vladimir, you have lost the ladder program for your mill. PM me and I will email instructions
    Keshka
  9. #169
    Apr 2006
    I have 1986-87 Hitachi-Seiki HT-20 Fanuc 10TE control cnc lathe. It was setting for a couple of months. went to hook it up and it boots up to ram test then stops and goes no further.... any suggestions?
    Jim Compton
    Visit www.manuals-depot.com Many tractor manuals available
  10. #170
    Member shas595's Avatar
    Dec 2009
    Hi Jim
    you might need to regen if it lost battery / data - you can pm me your email and Ill reach out to get you going
    John
  11. #171
    greelyman's Avatar
    Nov 2019
    Hi Josh, I have an HT23J. The tool unclamp/clamp piston hit the hydraulic tool release piston while the turret was indexing, & stopped the turret. I don’t know how to get it back to zero. Can you help me with the procedure to zero it?
    Its a Hitachi-Seiki HT23J with a Yasnak control.
    Thank you
    Mike
    greelyman@mac.com
  12. #172
    Dec 2009
    Mike
    I sent you an email, take a look. As long as nothing broke it should be a quick fix
    John
    Quote Originally Posted by greelyman View Post
    Thank you
    Mike
    greelyman@mac.com
  13. #173
    Aug 2012
    South africa
    Good Day
    Please can anybody help me with the datasheet for a Hitachi Seiki VA-40 Micon 8 system? All data was lost due to low battery.
    I am situated in South Africa. You can email me, jacof@mweb.co.za.
    Any help will be appreciated and thank you in advance.
    Jaco
  14. #174
    Apr 2007
    Indonesia
    Dear friends,
    How to set zero return procedure on Hitachi Seiki VM 40II,seicos 3?
    Thank You,Have a nice day
    Rizal
  15. #175
    Dec 2009
    Hello
    what do you mean? Did you lose data and now it is not going home but oevertravelling?
  16. #176
    Apr 2007
    Indonesia
    After SPHC card has changed,now the machine always overtravell when zero return performed
    Thanks for your attention Mr John
